Introduction
The heat sink helps disperse the heat from the laptop, it usually used in conjunction with the fan. If your laptop is overheating, you might need to replace the heatsink. The guide will demonstrate how to replace the heatsink step by step.
Ce dont vous avez besoin
Unclip the power supply by pulling the cable directly up and out of the socket.
Unscrew the four 8mm screws using a Phillips #1 screwdriver until the heatsink is free.
