Aller au contenu principal
Dell Vostro 1710 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Dell Vostro 1710 Wi-Fi Card Replacement, Battery: étape 1, image 1 de 2 Dell Vostro 1710 Wi-Fi Card Replacement, Battery: étape 1, image 2 de 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Wi-Fi Card Replacement, Back Panel: étape 4, image 1 de 2 Dell Vostro 1710 Wi-Fi Card Replacement, Back Panel: étape 4, image 2 de 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 1 de 2 Dell Vostro 1710 Wi-Fi Card Replacement, Wi-Fi Card: étape 6, image 2 de 2
    • Remove the two 3mm Philips #1 screws from the top of the Wi-Fi card.
  7. Dell Vostro 1710 Wi-Fi Card Replacement: étape 7, image 1 de 2 Dell Vostro 1710 Wi-Fi Card Replacement: étape 7, image 2 de 2
    • Unclip both black and white wires from the Wi-Fi card.
  8. Dell Vostro 1710 Wi-Fi Card Replacement: étape 8, image 1 de 1
    • Gently pull Wi-Fi card out of its position at its angle.
Jeremy Campeau
Membre depuis le 03/20/18
347 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G7, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G7, Peak Spring 2018
UMASSD-PEAK-S18S3G7
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 387
