Aller au contenu principal
Dell Vostro 3360 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: étape 1, image 1 de 1
    • Remove the screw that secures the keyboard to the chassis.
  2. Dell Vostro 3360 Hard Drive Replacement, Prying the Keyboard: étape 2, image 1 de 1
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  3. Dell Vostro 3360 Hard Drive Replacement, Flipping the Keyboard: étape 3, image 1 de 1
    • Flip the keyboard over and lay it on the palmrest.
  4. Dell Vostro 3360 Hard Drive Replacement, Lifting the Clip: étape 4, image 1 de 1
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  5. Dell Vostro 3360 Hard Drive Replacement, Remove the Screw: étape 5, image 1 de 1
    • Remove the screw that secures the access panel to the computer.
  6. Dell Vostro 3360 Hard Drive Replacement, Remove the Access Panel: étape 6, image 1 de 1
    • Remove the access panel from the computer.
  7. Dell Vostro 3360 Hard Drive Replacement, Display-Hinge Cover: étape 7, image 1 de 1
    • Remove the screws that secure the display-hinge cover to the computer
  8. Dell Vostro 3360 Hard Drive Replacement, Remove the Display Hinge Cover: étape 8, image 1 de 1
    • Remove the display-hinge cover from the computer.
  9. Dell Vostro 3360 Hard Drive Replacement, Prying the Rubber Pads: étape 9, image 1 de 1
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  10. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: étape 10, image 1 de 1
    • Remove the screws that secure the palm-rest to the computer.
  11. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the Board Cable: étape 11, image 1 de 1
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  12. Dell Vostro 3360 Hard Drive Replacement, Disconnecting the LED Cable: étape 12, image 1 de 1
    • Disconnect the power LED cable and the LED board cable from the system board.
  13. Dell Vostro 3360 Hard Drive Replacement, Remove the Screws: étape 13, image 1 de 1
    • Remove the screws that secure the palmrest to the front of the computer.
  14. Dell Vostro 3360 Hard Drive Replacement, Prying the Edges of the Palm-Rest: étape 14, image 1 de 1
    • Pry along the edges of the palmrest to release the palmrest.
  15. Dell Vostro 3360 Hard Drive Replacement, Lifting the Palm Rest: étape 15, image 1 de 1
    • Lift the palm-rest up and away from the computer.
  16. Dell Vostro 3360 Hard Drive Replacement, Hard Drive: étape 16, image 1 de 1
    • Remove the screws that secure the hard drive to the computer.
  17. Dell Vostro 3360 Hard Drive Replacement: étape 17, image 1 de 1
    • Lift the hard drive to disconnect the hard-drive cable
  18. Dell Vostro 3360 Hard Drive Replacement: étape 18, image 1 de 1
    • Disconnect the hard-drive cable from the hard drive and remove the hard drive from the computer
  19. Dell Vostro 3360 Hard Drive Replacement: étape 19, image 1 de 1
    • Remove the screws that secure the hard-drive bracket to the hard drive and remove the hard drive bracket from it.
4 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
44 953 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 23
Total : 3,214
