Introduction
In this guide, we will be showing you how to remove and replace the Palm-Rest.
Pièces
Aucune pièce nécessaire.
  1. Remove the screw that secures the access panel to the computer.
    • Remove the screw that secures the access panel to the computer.
  2. Remove the access panel from the computer.
    • Remove the access panel from the computer.
  3. Remove the screw that secures the keyboard to the chassis.
    • Remove the screw that secures the keyboard to the chassis.
  4. Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
    • Starting on the right side of the system, use a plastic scribe to pry up the keyboard from the computer.
  5. Flip the keyboard over and lay it on the palmrest.
    • Flip the keyboard over and lay it on the palmrest.
  6. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  7. Lift the clip to release the keyboard cable and disconnect it from the computer.
    • Lift the clip to release the keyboard cable and disconnect it from the computer.
  8. Remove the screws that secure the display-hinge cover to the computer
    • Remove the screws that secure the display-hinge cover to the computer
  9. Remove the display-hinge cover from the computer.
    • Remove the display-hinge cover from the computer.
  10. Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
    • Using a plastic scribe pry out the rubber pads that cover the front screws on the base cover.
  11. Remove the screws that secure the palm-rest to the computer.
    • Remove the screws that secure the palm-rest to the computer.
  12. Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
    • Disconnect the quick launch board cable, the finger print reader cable, and the palmrest cable from the system board.
  13. Disconnect the power LED cable and the LED board cable from the system board.
    • Disconnect the power LED cable and the LED board cable from the system board.
  14. Remove the screws that secure the palmrest to the front of the computer.
    • Remove the screws that secure the palmrest to the front of the computer.
  15. Pry along the edges of the palmrest to release the palmrest.
    • Pry along the edges of the palmrest to release the palmrest.
  16. Lift the palm-rest up and away from the computer.
    • Lift the palm-rest up and away from the computer.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 28/02/2018
35 786 Réputation
408 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
925 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 61
