Aller au contenu principal
Dell Vostro 3450 Palm Rest Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3450 Palm Rest Replacement, Unlocking the Battery: étape 1, image 1 de 1
    • Slide the left and the right battery release latches to the unlock position.
  2. Dell Vostro 3450 Palm Rest Replacement, Removing the Battery: étape 2, image 1 de 1
    • Slide the battery and remove it from the computer.
  3. Dell Vostro 3450 Palm Rest Replacement, Loosen the Screw: étape 3, image 1 de 1
    • Loosen the screw that secures the memory door.
  4. Dell Vostro 3450 Palm Rest Replacement, Removing the Memory Door: étape 4, image 1 de 1
    • Pry up the memory door near the screw hole, lift and remove it.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  5. Dell Vostro 3450 Palm Rest Replacement, Remove the Screw: étape 5, image 1 de 1
    • Remove the screw that secures the optical drive to the computer.
  6. Dell Vostro 3450 Palm Rest Replacement, Prying the Drive: étape 6, image 1 de 1
    • Gently pry the optical drive out of the computer.
  7. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: étape 7, image 1 de 1
    • Remove the screws that secure the optical drive bracket.
  8. Dell Vostro 3450 Palm Rest Replacement, Removing the Optical Drive: étape 8, image 1 de 1
    • Remove the optical drive bracket from the optical drive module.
  9. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: étape 9, image 1 de 1
    • Remove the screws in the battery compartment.
  10. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: étape 10, image 1 de 1
    • Remove the screws in the optical drive compartment.
  11. Dell Vostro 3450 Palm Rest Replacement, Remove the Rubber: étape 11, image 1 de 1
    • Remove the rubber from the bottom base on the right side.
  12. Dell Vostro 3450 Palm Rest Replacement, Remove the Rubber: étape 12, image 1 de 1
    • Remove the rubber from the bottom base on the left side.
  13. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: étape 13, image 1 de 1
    • Remove all the screws from the bottom base.
  14. Dell Vostro 3450 Palm Rest Replacement, Remove the Screws: étape 14, image 1 de 1
    • Flip the computer around and remove the screws that secures the palm rest.
  15. Dell Vostro 3450 Palm Rest Replacement, Release the Latches: étape 15, image 1 de 1
    • Release the latches on the system board connector, then disconnect the touch pad cable and the finger printer cable.
  16. Dell Vostro 3450 Palm Rest Replacement, Release the Latch: étape 16, image 1 de 1
    • Release the latch on the system board connector and then disconnect the power button cable.
  17. Dell Vostro 3450 Palm Rest Replacement, Disconnecting the Key Cable: étape 17, image 1 de 1
    • Release the latch on the system board connector and then disconnect the hot key cable.
  18. Dell Vostro 3450 Palm Rest Replacement, Prying the Palm Rest: étape 18, image 1 de 1
    • Pry up the right side of the palm rest.
  19. Dell Vostro 3450 Palm Rest Replacement, Prying the Palm Rest: étape 19, image 1 de 1
    • Pry up the left side of the palm rest.
  20. Dell Vostro 3450 Palm Rest Replacement, Prying the Sides: étape 20, image 1 de 1
    • Pry up the sides of the palm rest and remove it from the computer.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 02/28/18
45 034 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 989 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 149
