Aller au contenu principal
Dell Vostro 3510 Battery Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3510 Battery Replacement, Battery: étape 1, image 1 de 2 Dell Vostro 3510 Battery Replacement, Battery: étape 1, image 2 de 2
    • Ensure the laptop is powered off.
    • Flip the laptop over.
  2. Dell Vostro 3510 Battery Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Use a Phillips #0 screwdriver to remove the screws highlighted with red circles.
    • Loosen the two 1 mm captive screws (orange circles in the image) on the back corners of the bottom cover.
    • Keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
  3. Dell Vostro 3510 Battery Replacement: étape 3, image 1 de 2 Dell Vostro 3510 Battery Replacement: étape 3, image 2 de 2
    • Open up the back cover of the laptop.
    • It is much easier to open up the laptop with any type of spudger or with Jimmy.
  4. Dell Vostro 3510 Battery Replacement: étape 4, image 1 de 2 Dell Vostro 3510 Battery Replacement: étape 4, image 2 de 2
    • Remove the battery cable from the motherboard by lightly pulling on the black tape attached to the ribbon cable.
    • The battery cable is the one circled in red.
  5. Dell Vostro 3510 Battery Replacement: étape 5, image 1 de 1
    • Remove the 0.1 mm battery screws seen in picture one with Phillips #0 screwdriver.
    • Carefully move the additional sata storage ribbon cable to the side.
  6. Dell Vostro 3510 Battery Replacement: étape 6, image 1 de 1
    • Gently remove the battery from the laptop.
    • Be careful with the other ribbon cables.
Jhoan Cruz
Membre depuis le 02/01/24
483 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team 16-1, Gonzalez Spring 2024 Membre de l'équipe Gateway, Team 16-1, Gonzalez Spring 2024
GCC-GONZALEZ-S24S16G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 25
Total : 61
