Aller au contenu principal
Dell Vostro 3510 Display Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3510 Display Replacement, Display: étape 1, image 1 de 2 Dell Vostro 3510 Display Replacement, Display: étape 1, image 2 de 2
    • Ensure the laptop is powered off.
    • Flip the laptop over.
  2. Dell Vostro 3510 Display Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Use a Phillips #0 screwdriver to remove the six 1 mm screws (circled in red).
    • Loosen the two captive 1 mm screws on the back corners.
    • Keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
  3. Dell Vostro 3510 Display Replacement: étape 3, image 1 de 2 Dell Vostro 3510 Display Replacement: étape 3, image 2 de 2
    Metal Spudger
    $2.99
    J'achète
    • Open up the back cover of the laptop.
    • It is much easier to open up the laptop with any type of metal spudger or with Jimmy.
  4. Dell Vostro 3510 Display Replacement: étape 4, image 1 de 3 Dell Vostro 3510 Display Replacement: étape 4, image 2 de 3 Dell Vostro 3510 Display Replacement: étape 4, image 3 de 3
    • Start by unplugging the cable for display.
  5. Dell Vostro 3510 Display Replacement: étape 5, image 1 de 3 Dell Vostro 3510 Display Replacement: étape 5, image 2 de 3 Dell Vostro 3510 Display Replacement: étape 5, image 3 de 3
    • Remove the 1 mm screws in red circle with Phillips #0 screwdriver.
  6. Dell Vostro 3510 Display Replacement: étape 6, image 1 de 2 Dell Vostro 3510 Display Replacement: étape 6, image 2 de 2
    • Remove the 1 mm screws holding down the metal bracket in red circle with Phillips #0 screwdriver.
  7. Dell Vostro 3510 Display Replacement: étape 7, image 1 de 2 Dell Vostro 3510 Display Replacement: étape 7, image 2 de 2
    • Unplug both the white and black wire
    • The black wire is marked in red.
    • The white wire is marked in orange.
  8. Dell Vostro 3510 Display Replacement: étape 8, image 1 de 3 Dell Vostro 3510 Display Replacement: étape 8, image 2 de 3 Dell Vostro 3510 Display Replacement: étape 8, image 3 de 3
    • Lift up the hinges circled in red.
  9. Dell Vostro 3510 Display Replacement: étape 9, image 1 de 2 Dell Vostro 3510 Display Replacement: étape 9, image 2 de 2
    • Hold it at a angle and then it should slide off.
Jhoan Cruz
Membre depuis le 02/01/24
483 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team 16-1, Gonzalez Spring 2024 Membre de l'équipe Gateway, Team 16-1, Gonzalez Spring 2024
GCC-GONZALEZ-S24S16G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 42
Total : 52
