Aller au contenu principal
Dell Vostro 3550 Disk Drive Tray Latch Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: étape 1, image 1 de 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: étape 1, image 2 de 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement, Disk Drive Tray Latch Mechanism: étape 1, image 3 de 3
    • Push a paperclip that is bent straight into the small pin hole on the right of the release button.
    • When 3/4" of the paperclip is inserted the tray will pop open.
    • Pull the disk tray out as far as it will extend.
  2. Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 2, image 1 de 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 2, image 2 de 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 2, image 3 de 3
    • Flip the laptop over and position it so the disk drive is in front of you.
    • Remove the five 5mm Phillips #0 screws fastening the top plate to the disk tray.
  3. Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 3, image 1 de 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 3, image 2 de 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 3, image 3 de 3
    • Remove the top plate of the disk tray and place it off to the side.
  4. Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 4, image 1 de 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 4, image 2 de 3 Dell Vostro 3550 Disk Drive Tray Latch Replacement: étape 4, image 3 de 3
    • Remove the single 5mm Phillips #0 screw securing the latch mechanism to the disk drive.
    • Pull the damaged latch away from the disk drive and replace with the new latch.
Dylan J. Souza
Membre depuis le 03/22/19
781 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G6, Bailey Spring 2019
UMASSD-BAILEY-S19S8G6
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 264
