Aller au contenu principal
Dell Vostro 3550 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3550 Display Assembly Replacement, Display Assembly: étape 1, image 1 de 2 Dell Vostro 3550 Display Assembly Replacement, Display Assembly: étape 1, image 2 de 2
    • Grip the back trim of the laptop and pull upwards to remove it.
  2. Dell Vostro 3550 Display Assembly Replacement: étape 2, image 1 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 2, image 2 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 2, image 3 de 3
    • Slide the plastic opening tool around the perimeter of the display bezel.
    • Carefully remove the bezel from the display.
  3. Dell Vostro 3550 Display Assembly Replacement: étape 3, image 1 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 3, image 2 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 3, image 3 de 3
    • Remove the six 7 mm Phillips #0 screws attaching the display to the upper casing of the laptop.
    • When all six screws are removed, gently lower the display to reveal the camera cable.
  4. Dell Vostro 3550 Display Assembly Replacement: étape 4, image 1 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 4, image 2 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 4, image 3 de 3
    • Disconnect the camera ribbon cable by gently pulling it away from its connector.
  5. Dell Vostro 3550 Display Assembly Replacement: étape 5, image 1 de 2 Dell Vostro 3550 Display Assembly Replacement: étape 5, image 2 de 2
    • Remove the four 5 mm Phillips #0 screws (two on either side) securing the display to the metal frame.
  6. Dell Vostro 3550 Display Assembly Replacement: étape 6, image 1 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 6, image 2 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 6, image 3 de 3
    • Gently lower the display into a resting position.
  7. Dell Vostro 3550 Display Assembly Replacement: étape 7, image 1 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 7, image 2 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 7, image 3 de 3
    • Loosen the clear tape fastening the ribbon cable to the display.
    • Carefully pull the ribbon cable away from the connector.
  8. Dell Vostro 3550 Display Assembly Replacement: étape 8, image 1 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 8, image 2 de 3 Dell Vostro 3550 Display Assembly Replacement: étape 8, image 3 de 3
    • Peel the ribbon cable away from the display.
    • Remove the display from the laptop.
Dylan J. Souza
Membre depuis le 03/22/19
781 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G6, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G6, Bailey Spring 2019
UMASSD-BAILEY-S19S8G6
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 20
Total : 789
