Aller au contenu principal
Dell Vostro 3560 Optical Drive Replacement
Ce dont vous avez besoin
  1. Dell Vostro 3560 Optical Drive Replacement, Identify your laptop: étape 1, image 1 de 2 Dell Vostro 3560 Optical Drive Replacement, Identify your laptop: étape 1, image 2 de 2
    • Make sure you have the right laptop by checking the sticker.
  2. Dell Vostro 3560 Optical Drive Replacement, Remove Battery: étape 2, image 1 de 2 Dell Vostro 3560 Optical Drive Replacement, Remove Battery: étape 2, image 2 de 2
    • Start with your PC shut off and upside down.
    • Pull out tabs.
    • Pull up on rail to remove battery.
  3. Dell Vostro 3560 Optical Drive Replacement, Remove Back Panel: étape 3, image 1 de 1
    • Remove the two screws:
    • One M2 Phillips screw (Fixed)
    • One 5-mm M2 Phillips screw
  4. Dell Vostro 3560 Optical Drive Replacement: étape 4, image 1 de 3 Dell Vostro 3560 Optical Drive Replacement: étape 4, image 2 de 3 Dell Vostro 3560 Optical Drive Replacement: étape 4, image 3 de 3
    • Use a iFixit opening tool to remove the back panel.
  5. Dell Vostro 3560 Optical Drive Replacement: étape 5, image 1 de 1
    • From here you can access:
    • The hard drive
    • The RAM.
    • The CD Drive.
  6. Dell Vostro 3560 Optical Drive Replacement, Optical Drive: étape 6, image 1 de 1
    • We will focus on the Optical Drive.
  7. Dell Vostro 3560 Optical Drive Replacement, Remove Optical Drive: étape 7, image 1 de 1
    • Remove the 3-mm M2 Phillips screws.
  8. Dell Vostro 3560 Optical Drive Replacement: étape 8, image 1 de 3 Dell Vostro 3560 Optical Drive Replacement: étape 8, image 2 de 3 Dell Vostro 3560 Optical Drive Replacement: étape 8, image 3 de 3
    • Pull the optical drive out of the frame.
    • If it doesn't come out immediately, you might have to shake it.
Max Bareilles
Membre depuis le 02/24/20
664 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 439
