Aller au contenu principal
Dell Vostro 5459 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Vostro 5459 Hard Drive Replacement, Removing the Base Cover: étape 1, image 1 de 1
    • Remove the screws that secure the back cover to the computer.
    • Pry the edges of the back cover from all sides, to release the back cover.
    • Lift the back cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Dell Vostro 5459 Hard Drive Replacement, Removing the Battery: étape 2, image 1 de 1
    • Disconnect the battery cable from the connector on the system board [1].
    • Remove the screws that secure the battery to the computer [2].
    • Lift and remove the battery from the computer [3].
  3. Dell Vostro 5459 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Disconnect the hard drive cable from the connector on the system board [1] .
    • Remove the screws that secure the hard drive to the computer [2].
    • Lift the hard drive from the computer [3].
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
Un commentaire
Dell Vostro 14 5459 definitely is simple and easy to open. In absence of prying tool you can use even disposable plastic knife. Spent 15 minutes to disassemble, change HDD drive to SSD drive and assemble it back. Memory upgrade is easy as well - carefully peel off plastic sheet above RAM module and replace the RAM. Seems particular cooler design is not very prone to collect dust inside too so easier cleaning as well. If middle screw on assembly doesn’t stick in thread, slightly press keyboard in area where keys G,H,J are and try to screw the screw in again. For maintenance and upgrade for this laptop I give 4/5.
Jānis Baumanis - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,048
