Aller au contenu principal
Dell Vostro 5470 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Vostro 5470 Hard Drive Replacement, Remove the Screws: étape 1, image 1 de 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro 5470 Hard Drive Replacement, Loosening the Base Cover: étape 2, image 1 de 1
    • Pry the base cover along the edges to loosen it.
  3. Dell Vostro 5470 Hard Drive Replacement, Removing the Base Cover: étape 3, image 1 de 1
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 5470 Hard Drive Replacement, Disconnecting the Battery Cable: étape 4, image 1 de 1
    • Disconnect the battery cable from its connector on the system board.
  5. Dell Vostro 5470 Hard Drive Replacement, Releasing the Tabs: étape 5, image 1 de 1
    • Release the tabs that secure the battery in the battery bay.
  6. Dell Vostro 5470 Hard Drive Replacement, Removing the Battery: étape 6, image 1 de 1
    • Lift and remove the battery from the computer.
  7. Dell Vostro 5470 Hard Drive Replacement, Hard Drive: étape 7, image 1 de 1
    • Lift the hard drive assembly in an upward direction to release it from its compartment on the computer. Remove the hard drive from the computer.
  8. Dell Vostro 5470 Hard Drive Replacement: étape 8, image 1 de 1
    • Remove the screws that secure the hard drive to the hard drive assembly.
    • Lift and remove the hard drive from the hard drive assembly.
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 1,627
