Aller au contenu principal
Dell Vostro 5480 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Vostro 5480 Memory Module Replacement, Remove the Screws: étape 1, image 1 de 1
    • Remove the screws that secure the base cover to the computer.
  2. Dell Vostro 5480 Memory Module Replacement, Pry the Cover: étape 2, image 1 de 1
    • Pry the base cover along the edges to loosen it.
  3. Dell Vostro 5480 Memory Module Replacement, Removing the Base Cover: étape 3, image 1 de 1
    • Lift and remove the base cover from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  4. Dell Vostro 5480 Memory Module Replacement, Disconnecting the Battery Cable: étape 4, image 1 de 1
    • Disconnect the battery cable from its connector on the system board.
  5. Dell Vostro 5480 Memory Module Replacement, Release the Tabs: étape 5, image 1 de 1
    • Release the tabs that secure the battery in the battery bay.
  6. Dell Vostro 5480 Memory Module Replacement, Removing the Battery: étape 6, image 1 de 1
    • Lift and remove the battery from the computer.
  7. Dell Vostro 5480 Memory Module Replacement, Memory Module: étape 7, image 1 de 1
    • Pry the retention clips away from the memory module until it pops up. Remove the memory module from its connector on the system board.
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 243
