Aller au contenu principal
Dell Vostro 5510 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Vostro 5510 Display Assembly Replacement, Back Cover: étape 1, image 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Display Assembly Replacement: étape 2, image 1 de 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Display Assembly Replacement: étape 3, image 1 de 3 Dell Vostro 5510 Display Assembly Replacement: étape 3, image 2 de 3 Dell Vostro 5510 Display Assembly Replacement: étape 3, image 3 de 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Display Assembly Replacement: étape 4, image 1 de 3 Dell Vostro 5510 Display Assembly Replacement: étape 4, image 2 de 3 Dell Vostro 5510 Display Assembly Replacement: étape 4, image 3 de 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Display Assembly Replacement, Display Assembly: étape 5, image 1 de 3 Dell Vostro 5510 Display Assembly Replacement, Display Assembly: étape 5, image 2 de 3 Dell Vostro 5510 Display Assembly Replacement, Display Assembly: étape 5, image 3 de 3
    • Remove the six 4 mm hinge screws using the Phillips #0 screwdriver.
  6. Dell Vostro 5510 Display Assembly Replacement: étape 6, image 1 de 2 Dell Vostro 5510 Display Assembly Replacement: étape 6, image 2 de 2
    • Flip up the hinge panel for the left side of the laptop.
    • Flip up the hinge panel for the right side of the laptop.
  7. Dell Vostro 5510 Display Assembly Replacement: étape 7, image 1 de 2 Dell Vostro 5510 Display Assembly Replacement: étape 7, image 2 de 2
    • Disconnect the display cable with your hands.
  8. Dell Vostro 5510 Display Assembly Replacement: étape 8, image 1 de 1
    • Lift up the laptop with your hands to detach it from the display assembly.
2 autres ont terminé cette réparation.
Shawn Pan
Membre depuis le 02/08/24
139 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 19
Total : 175
