Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
In this guide, we will show you how to remove and replace the Hard Drive.
Pièces
Aucune pièce spécifiée.
  1. Remove the screw that secures the base cover to the computer.
    • Remove the screw that secures the base cover to the computer.
    • Pull the optical-drive and remove from the computer.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  2. Remove the screws that secure the base cover to the computer. Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
    • Remove the screws that secure the base cover to the computer.
    • Pry the base cover along the edges to loosen it. Lift and remove the base cover from the computer.
  3. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  4. Disconnect the battery cable from its connector on the system board.
    • Disconnect the battery cable from its connector on the system board.
    • Lift and remove the battery from the computer.
  5. Ease the I/O cable from the routing tabs.
    • Ease the I/O cable from the routing tabs.
    • Disconnect the hard-drive cable from the system board and remove the screws that secures the hard-drive in place
    • Lift and remove the hard-drive from the computer
  6. Disconnect the hard-drive connector from hard drive.
    • Disconnect the hard-drive connector from hard drive.
  7. Remove the screws that secure the hard-drive bracket to the hard drive. Separate the hard-drive bracket from the hard drive.
    • Remove the screws that secure the hard-drive bracket to the hard drive. Separate the hard-drive bracket from the hard drive.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 28/02/2018
36 815 Réputation
408 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
21 membres
1 816 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 71
