Aller au contenu principal
Dell Vostro A860 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Vostro A860 Keyboard Replacement, Keyboard: étape 1, image 1 de 2 Dell Vostro A860 Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Make sure the computer is powered down before beginning your work
    • Remove the battery and set it aside, there is a small clip that slides to free the battery.
    • Unscrew the two 4.7mm screws below the battery.
  2. Dell Vostro A860 Keyboard Replacement: étape 2, image 1 de 2 Dell Vostro A860 Keyboard Replacement: étape 2, image 2 de 2
    • Remove seven 8.6mm screws from the left and right side of the battery compartment
    • There are 2 screws to the left of the compartment, 3 to the right, and 2 along the bottom side.
  3. Dell Vostro A860 Keyboard Replacement: étape 3, image 1 de 3 Dell Vostro A860 Keyboard Replacement: étape 3, image 2 de 3 Dell Vostro A860 Keyboard Replacement: étape 3, image 3 de 3
    • Flip the laptop over and open it up.
    • Using a plastic opening tool carefully pry up along the edge of the plastic bezel at the top of the keyboard.
    • Getting the lip of the plastic opening tool under the edge of the bezel and moving it along the right and left edges helps to make removal easier.
  4. Dell Vostro A860 Keyboard Replacement: étape 4, image 1 de 2 Dell Vostro A860 Keyboard Replacement: étape 4, image 2 de 2
    • Remove two 5.5mm screws from the top of the keyboard
    • Using a plastic opening tool push inward along the edges of the keyboard to release the holding clips
  5. Dell Vostro A860 Keyboard Replacement: étape 5, image 1 de 1
    • Lift the keyboard upwards
    • Be careful not to pull too hard on the keyboard as it is still attached to the laptop by the ribbon connector.
    • Using the plastic opening tool push up on the black clip holding the connector ribbon.
    • Pull out the ribbon connector to remove the keyboard.
Joshua Dennis
Membre depuis le 03/25/16
528 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-5, Miles Spring 2016 Membre de l'équipe UMass Dartmouth, Team 1-5, Miles Spring 2016
UMASSD-MILES-S16S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 636
