Introduction
The top chassis plate with not remove completely without complete dis-assembly of the screen and hinges. It only needs to be lifted up and held in place while removing the speaker system.
Ce dont vous avez besoin
Remove the battery and set it aside, there is a small clip that slides to free the battery.
Unscrew the two 4.7mm screws below the battery.
With the laptop facing down remove one 4.7mm screw holding in the CD ROM unit.
Gently pull out on the CD ROM unit and remove it from the chassis.
Remove three 4.7mm screws located below where the CD ROM unit was inserted.
With the front of the top chassis plate lifted up locate the computer's speaker in the front right of the internal area.
Remove the two 5.5mm screws holding the speaker in place.
Using a plastic opening tool, or other flat headed tool, push the wires out of the connector to free the speaker for removal.
