Aller au contenu principal
Dell Vostro V13 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Vostro V13 Keyboard Replacement, Back Cover: étape 1, image 1 de 3 Dell Vostro V13 Keyboard Replacement, Back Cover: étape 1, image 2 de 3 Dell Vostro V13 Keyboard Replacement, Back Cover: étape 1, image 3 de 3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13 Keyboard Replacement: étape 2, image 1 de 3 Dell Vostro V13 Keyboard Replacement: étape 2, image 2 de 3 Dell Vostro V13 Keyboard Replacement: étape 2, image 3 de 3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13 Keyboard Replacement: étape 3, image 1 de 3 Dell Vostro V13 Keyboard Replacement: étape 3, image 2 de 3 Dell Vostro V13 Keyboard Replacement: étape 3, image 3 de 3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13 Keyboard Replacement: étape 4, image 1 de 2 Dell Vostro V13 Keyboard Replacement: étape 4, image 2 de 2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13 Keyboard Replacement: étape 5, image 1 de 3 Dell Vostro V13 Keyboard Replacement: étape 5, image 2 de 3 Dell Vostro V13 Keyboard Replacement: étape 5, image 3 de 3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13 Keyboard Replacement: étape 6, image 1 de 2 Dell Vostro V13 Keyboard Replacement: étape 6, image 2 de 2
    • Remove the battery.
    • Removing the battery allows you to work safely.
  7. Dell Vostro V13 Keyboard Replacement, Keyboard: étape 7, image 1 de 1
    • Open the laptop so the keyboard is visible.
  8. Dell Vostro V13 Keyboard Replacement: étape 8, image 1 de 3 Dell Vostro V13 Keyboard Replacement: étape 8, image 2 de 3 Dell Vostro V13 Keyboard Replacement: étape 8, image 3 de 3
    • Wedge the plastic opening tool around the seam of the notification panel to pop it off.
  9. Dell Vostro V13 Keyboard Replacement: étape 9, image 1 de 3 Dell Vostro V13 Keyboard Replacement: étape 9, image 2 de 3 Dell Vostro V13 Keyboard Replacement: étape 9, image 3 de 3
    • Disconnect the ribbon connector on the panel.
    • Remove the panel.
  10. Dell Vostro V13 Keyboard Replacement: étape 10, image 1 de 2 Dell Vostro V13 Keyboard Replacement: étape 10, image 2 de 2
    • Remove the two silver 3.1 mm Phillips #1 screws.
  11. Dell Vostro V13 Keyboard Replacement: étape 11, image 1 de 2 Dell Vostro V13 Keyboard Replacement: étape 11, image 2 de 2
    • Use the plastic opening tool to pry the keyboard out of the laptop.
    • Do not pull the keyboard all the way out yet.
  12. Dell Vostro V13 Keyboard Replacement: étape 12, image 1 de 2 Dell Vostro V13 Keyboard Replacement: étape 12, image 2 de 2
    • Disconnect the ribbon cable that connects the keyboard to the laptop by flipping up the white locking tab on the ZIF connector.
    • If you're having trouble, use the plastic opening tool to help.
  13. Dell Vostro V13 Keyboard Replacement: étape 13, image 1 de 3 Dell Vostro V13 Keyboard Replacement: étape 13, image 2 de 3 Dell Vostro V13 Keyboard Replacement: étape 13, image 3 de 3
    • Remove the keyboard.
Amy Ledermann
Membre depuis le 01/16/19
361 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 5
Total : 355
