Aller au contenu principal
Dell Wyse Xn0m Mouse Sensor Board Replacement
Ce dont vous avez besoin
  1. Dell Wyse Xn0m Mouse Sensor Board Replacement, Mouse Sensor Board: étape 1, image 1 de 1
    • Flip the device over. Unscrew nine marked 7mm Phillips #1 screws.
  2. Dell Wyse Xn0m Mouse Sensor Board Replacement: étape 2, image 1 de 2 Dell Wyse Xn0m Mouse Sensor Board Replacement: étape 2, image 2 de 2
    • Remove the keyboard by pushing back the tabs at the marked locations with a spudger or plastic opening tool.
  3. Dell Wyse Xn0m Mouse Sensor Board Replacement: étape 3, image 1 de 2 Dell Wyse Xn0m Mouse Sensor Board Replacement: étape 3, image 2 de 2
    • Turn the device around so the screen is closest to you. Lift the keyboard and detach the ribbon cable with the spudger.
    • To disconnect the cable, disengage the locking tab of the ZIF connector with the spudger and pull the cable out gently.
  4. Dell Wyse Xn0m Mouse Sensor Board Replacement: étape 4, image 1 de 1
    • Remove the keyboard and set it aside. Detach the other ribbon cables with the spudger.
    • Remove five 8mm Phillips #1 screws.
  5. Dell Wyse Xn0m Mouse Sensor Board Replacement: étape 5, image 1 de 1
    • Pry open the laptop with the plastic opening tool.
  6. Dell Wyse Xn0m Mouse Sensor Board Replacement: étape 6, image 1 de 2 Dell Wyse Xn0m Mouse Sensor Board Replacement: étape 6, image 2 de 2
    • Under the trackpad, detach the ribbon cables with the spudger.
    • Unscrew two 3mm Phillips #1 screws and lift the board from the pegs.
    • Remove the board from the laptop.
Jake Milligan
Membre depuis le 10/30/19
296 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team S2-G1, Kim Fall 2019 Membre de l'équipe University of Memphis, Team S2-G1, Kim Fall 2019
UM-KIM-F19S2G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 18
Total : 612
