Aller au contenu principal
Dell XPS 10 USB Port Replacement
Ce dont vous avez besoin
  1. Dell XPS 10 USB Port Replacement, Battery: étape 1, image 1 de 3 Dell XPS 10 USB Port Replacement, Battery: étape 1, image 2 de 3 Dell XPS 10 USB Port Replacement, Battery: étape 1, image 3 de 3
    • Slide one of the plastic opening tools in the crack on the side of the device with the windows button.
    • Slide the other plastic opening tool facing the opposite way in the crack next to the first one and pry the back cover off a little bit at a time or slide them around the edge as necessary.
    • Finally, slide the two plastic opening tools all around the case until it is open.
  2. Dell XPS 10 USB Port Replacement: étape 2, image 1 de 3 Dell XPS 10 USB Port Replacement: étape 2, image 2 de 3 Dell XPS 10 USB Port Replacement: étape 2, image 3 de 3
    • Unscrew the three black, 4mm screws with a phillips screwdriver size PH 0 (one of which is under the gold colored ribbon cable.)
    • Unscrew the three gray, 3mm screws with the same screwdriver (phillips screwdriver size PH 0.)
    • Unplug the connector the connects the battery to the mother board.
    • Make sure to use a plastic opening tool instead of a metal spudger to avoid any unnecessary accidental shorting out of components.
  3. Dell XPS 10 USB Port Replacement, USB Port: étape 3, image 1 de 3 Dell XPS 10 USB Port Replacement, USB Port: étape 3, image 2 de 3 Dell XPS 10 USB Port Replacement, USB Port: étape 3, image 3 de 3
    • Use the plastic opening tools to lift up the black cable shown in the picture.
    • Slide one end of the speaker to the other side and the speaker will be out.
  4. Dell XPS 10 USB Port Replacement: étape 4, image 1 de 3 Dell XPS 10 USB Port Replacement: étape 4, image 2 de 3 Dell XPS 10 USB Port Replacement: étape 4, image 3 de 3
    • Unscrew the shown screw in the picture.
    • Remove the silver tape using the plastic tool as shown in the picture.
    • Note: be careful when removing the tape as it is fragile.
  5. Dell XPS 10 USB Port Replacement: étape 5, image 1 de 3 Dell XPS 10 USB Port Replacement: étape 5, image 2 de 3 Dell XPS 10 USB Port Replacement: étape 5, image 3 de 3
    • Unscrew the three screws shown in the picture.
    • 3 mm screws.
    • Slide the small piece shown in green square on both black pieces and lift them up using the plastic tool as shown in the picture.
    • Finally, take the USB port out. You will have three pieces out: the port and the two black pieces as shown in the picture.
James
Membre depuis le 10/04/16
401 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 2-1, Nance Fall 2016 Membre de l'équipe USF Tampa, Team 2-1, Nance Fall 2016
USFT-NANCE-F16S2G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 1,790
