Aller au contenu principal
Dell XPS 12 9Q33 Battery Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 3 sont issues d'un tutoriel marqué comme en cours.
    Dell XPS 12 9Q33 Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Use your fingers or a spudger to pry up the system badge from the bottom of the laptop.
  2. Dell XPS 12 9Q33 Battery Replacement: étape 2, image 1 de 1
    • Use a Phillips screwdriver to remove the eleven screws securing the base cover.
  3. Dell XPS 12 9Q33 Battery Replacement: étape 3, image 1 de 1
    • Beginning with the side opposite the power switch, use your fingers to pry up the base cover from the laptop.
    • Carefully lift the base cover around the power switch and remove the cover.
  4. Dell XPS 12 9Q33 Battery Replacement, Removing the Battery: étape 4, image 1 de 1
    • Slide the battery cable connector out of its system board socket.
    • Pull parallel to the motherboard, not straight up, or you will damage the socket.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Lift and remove the battery along with its cable.
    • Slide and hold the power switch for about five seconds to ground the system board.
2 autres ont terminé cette réparation.
Johnathan Hammond
Membre depuis le 02/28/18
44 830 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 1,086
