Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Dell XPS 13 9360 SSD Replacement
Ce dont vous avez besoin
  1. Dell XPS 13 9360 SSD Replacement, SSD (Solid State Drive): étape 1, image 1 de 1
    • Power off your laptop and unplug it from the charger.
    Demander à FixBot
    Ajouter un commentaire
  2. Dell XPS 13 9360 SSD Replacement: étape 2, image 1 de 2 Dell XPS 13 9360 SSD Replacement: étape 2, image 2 de 2
    • Close the laptop lid and place it so the bottom side faces up.
    Demander à FixBot
  3. Dell XPS 13 9360 SSD Replacement: étape 3, image 1 de 3 Dell XPS 13 9360 SSD Replacement: étape 3, image 2 de 3 Dell XPS 13 9360 SSD Replacement: étape 3, image 3 de 3
    • Use a Torx T5 screwdriver to remove eight 3 mm screws around the edge of the back cover.
    Demander à FixBot
  4. Dell XPS 13 9360 SSD Replacement: étape 4, image 1 de 3 Dell XPS 13 9360 SSD Replacement: étape 4, image 2 de 3 Dell XPS 13 9360 SSD Replacement: étape 4, image 3 de 3
    • Lift the small magnetic flap cover in the center of the back case.
    • Use a JIS J0 screwdriver to remove the 6 mm screw under the flap cover.
    Demander à FixBot
  5. Dell XPS 13 9360 SSD Replacement: étape 5, image 1 de 3 Dell XPS 13 9360 SSD Replacement: étape 5, image 2 de 3 Dell XPS 13 9360 SSD Replacement: étape 5, image 3 de 3
    • Wedge the guitar pick between the cover and the base of the laptop.
    • Start at the front edge of the base cover and continue around the perimeter of the laptop, carefully prying up the base cover.
    • Pull off the base cover.
    • As you use the guitar pick to work around the base cover, it will gradually loosen. You can then gently pull it off completely.
    Demander à FixBot
  6. Dell XPS 13 9360 SSD Replacement: étape 6, image 1 de 3 Dell XPS 13 9360 SSD Replacement: étape 6, image 2 de 3 Dell XPS 13 9360 SSD Replacement: étape 6, image 3 de 3
    • Disconnect the battery before removing the SSD.
    • Use the JIS J0 screwdriver to remove the single 2 mm screw securing the existing SSD.
    • The SSD will automatically "pop up".
    • Gently slide it out from the socket.
    Demander à FixBot
  7. Dell XPS 13 9360 SSD Replacement: étape 7, image 1 de 2 Dell XPS 13 9360 SSD Replacement: étape 7, image 2 de 2
    • Slide the new SSD into the slot at the same angle used when removing the old one.
    • Make sure to align the notches on the SSD correctly with the tab openings of the slot to avoid damaging the SSD and the PCIe slot.
    • Press down on the SSD gently to hold it down.
    Demander à FixBot
  8. Dell XPS 13 9360 SSD Replacement: étape 8, image 1 de 3 Dell XPS 13 9360 SSD Replacement: étape 8, image 2 de 3 Dell XPS 13 9360 SSD Replacement: étape 8, image 3 de 3
    • Follow the remaining instructions in reverse order to reassemble.
    • Make sure that when you replace the back cover you press down along the edges to ensure that it snaps back into place.
    Demander à FixBot
  9. Dell XPS 13 9360 SSD Replacement: étape 9, image 1 de 2 Dell XPS 13 9360 SSD Replacement: étape 9, image 2 de 2
    • Now you can power on the laptop again and use it!
    Demander à FixBot
2 autres ont terminé cette réparation.
Diana Ramirez-S.
Membre depuis le 03/03/24
317 Réputation
1 tutoriel rédigé
Équipe
1 commentaire de tutoriel
Simple instructions. Could have used a little more detail in step 6 on how to disconnect the battery cable.
Rich Stillman - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 80
Total : 1,684
