Aller au contenu principal
Dell XPS 13 L321X Mouse pad Replacement
Ce dont vous avez besoin
  1. Dell XPS 13 L321X Mouse pad Replacement, Track Pad: étape 1, image 1 de 2 Dell XPS 13 L321X Mouse pad Replacement, Track Pad: étape 1, image 2 de 2
    • Remove ten 3mm screws from the back cover with a T5 screwdriver.
  2. Dell XPS 13 L321X Mouse pad Replacement: étape 2, image 1 de 2 Dell XPS 13 L321X Mouse pad Replacement: étape 2, image 2 de 2
    • Disconnect the ribbon cable with a plastic iFixit opening tool, by lifting up the black clip and by pulling the white ribbon off.
    • Pull aside the ribbon cable.
  3. Dell XPS 13 L321X Mouse pad Replacement: étape 3, image 1 de 1
    • With a plastic iFixit opeing tool, insert it in between and remove the battery cable.
  4. Dell XPS 13 L321X Mouse pad Replacement: étape 4, image 1 de 2 Dell XPS 13 L321X Mouse pad Replacement: étape 4, image 2 de 2
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
    • Lift the battery out.
  5. Dell XPS 13 L321X Mouse pad Replacement: étape 5, image 1 de 1
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and by pulling the white ribbon.
    • Place aside.
  6. Dell XPS 13 L321X Mouse pad Replacement: étape 6, image 1 de 3 Dell XPS 13 L321X Mouse pad Replacement: étape 6, image 2 de 3 Dell XPS 13 L321X Mouse pad Replacement: étape 6, image 3 de 3
    • Remove four 2mm screws with a PH00 screwdriver.
    • Remove the mouse pad.
Ligne d'arrivée
Ahmad EL Herbawi
Membre depuis le 03/01/17
499 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S6-G3, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 11
Total : 803
