Aller au contenu principal
Dell XPS 13 L321X Screen Replacement
Ce dont vous avez besoin
  1. Dell XPS 13 L321X Screen Replacement, Screen: étape 1, image 1 de 2 Dell XPS 13 L321X Screen Replacement, Screen: étape 1, image 2 de 2
    • Remove ten 3mm screws from the back cover with a "T5" screwdriver.
  2. Dell XPS 13 L321X Screen Replacement: étape 2, image 1 de 1
    • Remove the ribbons from both sides with a plastic iFixit opening tool.
  3. Dell XPS 13 L321X Screen Replacement: étape 3, image 1 de 2 Dell XPS 13 L321X Screen Replacement: étape 3, image 2 de 2
    • Remove the black wire that connects the screen to the motherboard by pulling up with a plastic iFixit opening tool.
  4. Dell XPS 13 L321X Screen Replacement: étape 4, image 1 de 2 Dell XPS 13 L321X Screen Replacement: étape 4, image 2 de 2
    • Disconnect the ribbon cable with a plastic iFixit opening tool by lifting up the black clip and pulling the white ribbon off.
    • Pull aside the ribbon cable.
  5. Dell XPS 13 L321X Screen Replacement: étape 5, image 1 de 3 Dell XPS 13 L321X Screen Replacement: étape 5, image 2 de 3 Dell XPS 13 L321X Screen Replacement: étape 5, image 3 de 3
    • Disconnect the wire that is connected to the wireless card with a plastic iFixit opening tool by lifting up slowly, then pulling the wires aside.
  6. Dell XPS 13 L321X Screen Replacement: étape 6, image 1 de 1
    • Use a PH00 size screwdriver to remove the 8 screws that secure the battery.
    • Six 3mm screws.
    • Two 5mm screws.
  7. Dell XPS 13 L321X Screen Replacement: étape 7, image 1 de 2 Dell XPS 13 L321X Screen Replacement: étape 7, image 2 de 2
    • Insert a plastic iFixit opening tool in between the port and the wires to remove the battery cable.
  8. Dell XPS 13 L321X Screen Replacement: étape 8, image 1 de 3 Dell XPS 13 L321X Screen Replacement: étape 8, image 2 de 3 Dell XPS 13 L321X Screen Replacement: étape 8, image 3 de 3
    • After removing the battery, start to remove the wireless wire and making it through the other wires connected under the battery.
  9. Dell XPS 13 L321X Screen Replacement: étape 9, image 1 de 2 Dell XPS 13 L321X Screen Replacement: étape 9, image 2 de 2
    • Remove the screws with a PH1 size screwdriver.
    • Each side of the brackets that are holding the screen down are going to have two 3mm screws in each side.
  10. Dell XPS 13 L321X Screen Replacement: étape 10, image 1 de 3 Dell XPS 13 L321X Screen Replacement: étape 10, image 2 de 3 Dell XPS 13 L321X Screen Replacement: étape 10, image 3 de 3
    • Open the laptop by separating the screen from the actual laptop and take it apart.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Molly Skinner
Membre depuis le 02/15/17
270 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S6-G3, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S6-G3, Lacy Spring 2017
USFT-LACY-S17S6G3
4 membres
5 tutoriels rédigés
2 commentaires
That would be the guide to take off the upper DISPLAY ASSEMBLY, not the screen.
I was expecting you to bring iOpeners and get the actual glass LCD out …
But it’s a good guide.
Xavier Jiang - Réponse
Is there a way only the screen can be replaced on Dell XPS 13, not the entire display assembly. From what I have got so far, the entire panel above the keyboard is a single unit
Abhi B - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 4,261
