Introduction
If your laptop is suffering from a faulty optical drive and the device is not able to read disks, it may be time for a replacement.
Ce dont vous avez besoin
Locate the spring latch on the bottom of the device that will unlatch the battery.
Hold the spring latch in the open position and pull the battery out of its recess.
Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
Pull the panel upwards and towards the battery to remove.
Put the panel to the side, exposing the RAM.
Locate and remove (1) 8.5mm JIS 1 screw at the top left corner of the RAM bay.
