Aller au contenu principal
Dell XPS 14 L401X Palm Rest Replacement
Ce dont vous avez besoin
  1. Dell XPS 14 L401X Palm Rest Replacement, Battery: étape 1, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement, Battery: étape 1, image 2 de 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
  2. Dell XPS 14 L401X Palm Rest Replacement, RAM: étape 2, image 1 de 3 Dell XPS 14 L401X Palm Rest Replacement, RAM: étape 2, image 2 de 3 Dell XPS 14 L401X Palm Rest Replacement, RAM: étape 2, image 3 de 3
    • Use a JIS 1 screwdriver to loosen the (2) captive screws from the panel.
    • The captive screws will not come off of the panel.
    • Pull the panel upwards and towards the battery to remove.
    • Put the panel to the side, exposing the RAM.
  3. Dell XPS 14 L401X Palm Rest Replacement: étape 3, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement: étape 3, image 2 de 2
    • The RAM is held by two spring clips. Pull at the two spring clips and the RAM will move upwards.
    • Keep your fingers on the edge of the chip.
    • Only handle the RAM by the sides! Do not touch the circuits or the terminals to avoid contamination!
  4. Dell XPS 14 L401X Palm Rest Replacement, Optical Drive: étape 4, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement, Optical Drive: étape 4, image 2 de 2
    • Locate and remove (1) 8.5mm JIS 1 screw at the top left corner of the RAM bay.
  5. Dell XPS 14 L401X Palm Rest Replacement: étape 5, image 1 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 5, image 2 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 5, image 3 de 3
    • Carefully pull out the optical drive from its bay.
  6. Dell XPS 14 L401X Palm Rest Replacement: étape 6, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement: étape 6, image 2 de 2
    • Carefully pull off the decorative cover from the front of the optical drive.
    • This decorative cover will be transferred to the new optical drive.
  7. Dell XPS 14 L401X Palm Rest Replacement: étape 7, image 1 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 7, image 2 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 7, image 3 de 3
    • Use a JIS 1 screwdriver to remove (2) 2mm screws on the drive's anchoring bracket.
    • This bracket will be transferred to the new optical drive.
  8. Dell XPS 14 L401X Palm Rest Replacement, Hard Drive: étape 8, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement, Hard Drive: étape 8, image 2 de 2
    • Use a JIS 1 screwdriver to remove (2) 2.5mm screws located on the right side of the RAM bay.
  9. Dell XPS 14 L401X Palm Rest Replacement: étape 9, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement: étape 9, image 2 de 2
    • Push the hard drive to the right with a spudger to unseat it from its socket while pulling out the hard drive with your other hand.
  10. Dell XPS 14 L401X Palm Rest Replacement: étape 10, image 1 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 10, image 2 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 10, image 3 de 3
    • Use a JIS 1 screwdriver to remove (1) 2.5mm screw attaching the plastic cosmetic cover to the hard drive.
    • Detach the plastic cosmetic cover from the hard drive.
    • This cosmetic cover will be transferred to the new hard drive.
  11. Dell XPS 14 L401X Palm Rest Replacement, Mini Card: étape 11, image 1 de 3 Dell XPS 14 L401X Palm Rest Replacement, Mini Card: étape 11, image 2 de 3 Dell XPS 14 L401X Palm Rest Replacement, Mini Card: étape 11, image 3 de 3
    • Locate the mini card access panel marked with a radio tower emblem on the bottom of the laptop near the battery bay.
    • Use a JIS 1 screwdriver to loosen the captive screw securing the panel to the device.
    • The captive screw will not come off of the panel.
    • Carefully remove the panel by prying it upwards, unlocking it from the tabs that are securing it in place.
  12. Dell XPS 14 L401X Palm Rest Replacement: étape 12, image 1 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 12, image 2 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 12, image 3 de 3
    • Disconnect the two wires on the mini card by carefully plucking them upwards by the metal contact points at the terminals.
    • Do not pluck the contacts off of the terminals by pulling on the wires, this can damage the cables.
    • Remove (1) 2mm screw from the bottom left corner of the mini card with a JIS 1 screwdriver.
  13. Dell XPS 14 L401X Palm Rest Replacement: étape 13, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement: étape 13, image 2 de 2
    • Remove the mini card as it flips upward.
  14. Dell XPS 14 L401X Palm Rest Replacement, Palm Rest: étape 14, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement, Palm Rest: étape 14, image 2 de 2
    • Remove two 4.5mm screws with JIS 1 screwdriver marked by the letter "K" in the optical drive bay.
  15. Dell XPS 14 L401X Palm Rest Replacement: étape 15, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement: étape 15, image 2 de 2
    • Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K"in the hard drive bay.
  16. Dell XPS 14 L401X Palm Rest Replacement: étape 16, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement: étape 16, image 2 de 2
    • Remove (2) 4.5mm screws with JIS 1 screwdriver marked by the letter "K" near Battery
  17. Dell XPS 14 L401X Palm Rest Replacement: étape 17, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement: étape 17, image 2 de 2
    • Remove (1) 7.5mm screw with JIS 1 screwdriver marked by the letter "K" in the RAM bay.
  18. Dell XPS 14 L401X Palm Rest Replacement: étape 18, image 1 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 18, image 2 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 18, image 3 de 3
    • Open the display to provide room for the palm rest to come out.
    • In the hard drive bay, push the "push" pad to lift up the palm rest.
  19. Dell XPS 14 L401X Palm Rest Replacement: étape 19, image 1 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 19, image 2 de 3 Dell XPS 14 L401X Palm Rest Replacement: étape 19, image 3 de 3
    • Disconnect the track pad cable by flipping up the gray clamp and lifting the cable up.
  20. Dell XPS 14 L401X Palm Rest Replacement: étape 20, image 1 de 2 Dell XPS 14 L401X Palm Rest Replacement: étape 20, image 2 de 2
    • Disconnect the status bar cable by pulling the pin connector upward.
    • Finish lifting up the palm rest.
Phelan Mascitelli
Membre depuis le 10/19/17
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S4-G3, Julie Fall 2017 Membre de l'équipe UMass Dartmouth, Team S4-G3, Julie Fall 2017
UMASSD-JULIE-F17S4G3
3 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 362
