Aller au contenu principal
Introduction
The battery is the main power supply to the laptop. Keeping a healthy battery is good for your device's health. A worn out battery can cause overheating of the device and it will have a shorter battery life. The removal of the battery is fairly simple and this guide will show you how to remove it. You will need a plastic opening tool and a Phillips #0 screwdriver.
Pièces
Aucune pièce spécifiée.
  1. Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Using the plastic opening tool, pry up the back cover. It is recommended to start from a corner and run the tool along the edge of the cover.
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. The battery is on the bottom left side.
    • The battery is on the bottom left side.
  4. Unscrew the five 4.5mm Phillips #0 screws around the battery.
    • Unscrew the five 4.5mm Phillips #0 screws around the battery.
  5. Using the plastic opening tools, carefully unplug the battery connection. Then, plug your replacement battery into the new connection.
    • Using the plastic opening tools, carefully unplug the battery connection.
    • Then, plug your replacement battery into the new connection.
3 autre(s) ont terminé cette réparation.
Colton Niewolny
Membre depuis le 15/02/2018
403 Réputation
4 tutoriels rédigés
Équipe
UW Stout, Team S8-G3, Ogden Spring 2018 Membre de l'équipe UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 membres
6 tutoriels rédigés
It worked smoothly! Less than 15 minutes. I used a OEM-battery, instead of an original one.
Jean Wallemacq - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 39
Total : 727
