Aller au contenu principal
Introduction
The hard drive holds the entire memory for the device. Without the hard drive, your device is completely useless. It is fairly easy to replace. When taking off the plastic protection, make sure not to bend the metal parts of the plastic because it will be difficult to put back into place. For this guide you will need a plastic opening tool and a Phillips #0 screwdriver.
Pièces
Aucune pièce spécifiée.
  1. Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
    • Remove the back cover of the laptop by unscrewing eight 3.5mm screws using a Phillips #0 screwdriver.
  2. Using the plastic opening tool, pry up the back cover. It is recommended to start from a corner and run the tool along the edge of the cover.
    • Using the plastic opening tool, pry up the back cover.
    • It is recommended to start from a corner and run the tool along the edge of the cover.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Locate the hard drive on the bottom right corner. Unscrew the three 3.5mm screws with the Phillips #0 screwdriver.
    • Locate the hard drive on the bottom right corner.
    • Unscrew the three 3.5mm screws with the Phillips #0 screwdriver.
  5. Remove the four additional 3.5mm screws using the Phillips #0 screwdriver.
    • Remove the four additional 3.5mm screws using the Phillips #0 screwdriver.
  6. Carefully pull and remove the old hard drive.
    • Carefully pull and remove the old hard drive.
Colton Niewolny
Membre depuis le 15/02/2018
403 Réputation
4 tutoriels rédigés
Équipe
UW Stout, Team S8-G3, Ogden Spring 2018 Membre de l'équipe UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 300
