Aller au contenu principal
Dell XPS 14Z L412Z LCD Screen Glass Replacement
Ce dont vous avez besoin
  1. Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: étape 1, image 1 de 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: étape 1, image 2 de 2
    • Using the iFixit opening tools, carefully pry up the trim around the screen.
    • It is recommended to start in a corner.
  2. Dell XPS 14Z L412Z LCD Screen Glass Replacement: étape 2, image 1 de 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: étape 2, image 2 de 2
    • Using a heat gun, carefully apply heat evenly across the glass.
  3. Dell XPS 14Z L412Z LCD Screen Glass Replacement: étape 3, image 1 de 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: étape 3, image 2 de 2
    • Using the iFixit opening tools, carefully pry the glass off the screen.
    • This is glass and will shatter if too much force is used.
Colton Niewolny
Membre depuis le 02/15/18
411 Réputation
4 tutoriels rédigés
Équipe
UW Stout, Team S8-G3, Ogden Spring 2018 Membre de l'équipe UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 membres
6 tutoriels rédigés
Un commentaire
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
wiwi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 13
Total : 2,120
