Aller au contenu principal
Dell XPS 15 9500 SSD Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9500 SSD Replacement, Base Panel: étape 1, image 1 de 1
    • Remove the eight 3.0 mm screws from the bottom panel with a T5 Torx screwdriver.
  2. Dell XPS 15 9500 SSD Replacement: étape 2, image 1 de 2 Dell XPS 15 9500 SSD Replacement: étape 2, image 2 de 2
    • Gently wedge an opening tool in the gap between the base panel and chassis, and pry vertically around the perimeter until it releases from the chassis.
    • Lift the base panel up and away from the chassis.
  3. Dell XPS 15 9500 SSD Replacement, SSD: étape 3, image 1 de 1
    • Use a Phillips #000 screwdriver to remove the single 3.0 mm screw on the right side of the SSD.
  4. Dell XPS 15 9500 SSD Replacement: étape 4, image 1 de 1
    • Lift the card a few millimeters, then pull it directly out of its slot.
  5. Dell XPS 15 9500 SSD Replacement: étape 5, image 1 de 2 Dell XPS 15 9500 SSD Replacement: étape 5, image 2 de 2
    • If you wish to install a second SSD, there is an empty slot for an additional SSD underneath the copper cover. If you're just replacing the existing SSD, stop here.
    • Use a Phillips #000 screwdriver to remove the one 3.0 mm screw on the left side of the SSD slot.
    • Pull the cover out directly toward the left.
Bryan Chung
Membre depuis le 10/18/19
437 Réputation
4 tutoriels rédigés
Équipe
UC Santa Barbara, Team A-1, Bator Winter 2022 Membre de l'équipe UC Santa Barbara, Team A-1, Bator Winter 2022
UCSB-BATOR-W22SAG1
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 21
30 derniers jours : 71
Total : 4,759
