Aller au contenu principal
Dell XPS 15 9510 Headphone Jack Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9510 Headphone Jack Replacement, Lower Case: étape 1, image 1 de 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Headphone Jack Replacement: étape 2, image 1 de 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Headphone Jack Replacement: étape 3, image 1 de 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Headphone Jack Replacement, Headphone Jack: étape 4, image 1 de 2 Dell XPS 15 9510 Headphone Jack Replacement, Headphone Jack: étape 4, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the three screws securing the headphone jack back to the panel.
    • Gently lift the headphone jack slightly to ensure it is free from the panel, but do not force it out.
    • Handle the component carefully to avoid damaging nearby connectors.
  5. Dell XPS 15 9510 Headphone Jack Replacement: étape 5, image 1 de 1
    • Carefully lift the headphone jack off the removed back panel. Check for any remaining cables or connections before fully removing it. Set the old headphone jack aside and prepare the replacement part.
    • Place the replacement headphone jack onto the back panel, aligning it with the screw holes.
    • Secure the three screws in place using a Phillips #00 screwdriver.
    • Reconnect any cables or connectors that were detached during removal.
    • Before fully reassembling the laptop, test the new headphone jack by plugging in a pair of headphones and playing audio. This helps confirm proper functionality before sealing the device back up.
Once the new headphone jack is installed and the laptop is reassembled, test the audio by plugging in headphones and playing sound from different applications. If issues persist, check the connector to ensure it is securely attached.
Austin Sa
Membre depuis le 03/30/22
432 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Mellen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-3, Mellen Spring 2022
UMASSD-MELLEN-S22S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 24
Total : 1,370
