Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
How to replace the memory modules of a Dell XPS 15 9530.
Pièces
Aucune pièce spécifiée.
  1. After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • After turning off the system, unscrew the 12 Philips screws (#1) that are on the bottom of the laptop.
    • Don't forget to unscrew the two screws hidden under the system badge!
  2. Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
    • Using a spudger or some other prying tool (#1), pry off the base-cover assembly from the rest of the system.
  3. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  4. Remove the screws that secure the battery to the palm-rest assembly.
    • Remove the screws that secure the battery to the palm-rest assembly.
    • Disconnect the battery cable from the system board.
    • Lift the battery off the palm-rest assembly.
    • After you remove the battery, turn the computer over, open the display, and press the power button for about five seconds to ground the system board.
  5. Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module connector until the memory module pops up.
    • Remove the memory module from the memory-module connector.
  6. Align the notch on the New memory module with the tab on the memory-module connector.
    • Align the notch on the New memory module with the tab on the memory-module connector.
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
To reassemble your device, put the battery back in and reaffix the base-cover assembly to the system.
Johnathan Hammond
Membre depuis le 28/02/2018
36 815 Réputation
408 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
21 membres
1 816 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 244
