Aller au contenu principal
Dell XPS 15 9530 Screen Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9530 Screen Replacement, Base Cover: étape 1, image 1 de 3 Dell XPS 15 9530 Screen Replacement, Base Cover: étape 1, image 2 de 3 Dell XPS 15 9530 Screen Replacement, Base Cover: étape 1, image 3 de 3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 Screen Replacement: étape 2, image 1 de 2 Dell XPS 15 9530 Screen Replacement: étape 2, image 2 de 2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 Screen Replacement: étape 3, image 1 de 1
    • Lift the lower case off.
  4. Dell XPS 15 9530 Screen Replacement, Battery: étape 4, image 1 de 2 Dell XPS 15 9530 Screen Replacement, Battery: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  5. Dell XPS 15 9530 Screen Replacement: étape 5, image 1 de 1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  6. Dell XPS 15 9530 Screen Replacement: étape 6, image 1 de 1
    • Lift the battery off the chassis.
  7. Dell XPS 15 9530 Screen Replacement, SSD: étape 7, image 1 de 1
    • Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
  8. Dell XPS 15 9530 Screen Replacement: étape 8, image 1 de 2 Dell XPS 15 9530 Screen Replacement: étape 8, image 2 de 2
    • Using a Phillips #0 screwdriver, remove two 2.5mm screws that secure the SSD to the chassis.
  9. Dell XPS 15 9530 Screen Replacement: étape 9, image 1 de 1
    • Pull the SSD out parallel to the mainboard.
  10. Dell XPS 15 9530 Screen Replacement, Screen: étape 10, image 1 de 2 Dell XPS 15 9530 Screen Replacement, Screen: étape 10, image 2 de 2
    • Unplug the screen connector.
  11. Dell XPS 15 9530 Screen Replacement: étape 11, image 1 de 2 Dell XPS 15 9530 Screen Replacement: étape 11, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws holding in the screen hinges.
  12. Dell XPS 15 9530 Screen Replacement: étape 12, image 1 de 1
    • Pull chassis away from screen assembly.
Larissa Omura
Membre depuis le 04/04/19
743 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 25
Total : 996
