Aller au contenu principal
Dell XPS 15 9530 WiFi Card Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9530 WiFi Card Replacement, Base Cover: étape 1, image 1 de 3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: étape 1, image 2 de 3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: étape 1, image 3 de 3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 WiFi Card Replacement: étape 2, image 1 de 2 Dell XPS 15 9530 WiFi Card Replacement: étape 2, image 2 de 2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 WiFi Card Replacement: étape 3, image 1 de 1
    • Lift the lower case off.
  4. Dell XPS 15 9530 WiFi Card Replacement, WiFi Card: étape 4, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the screw holding the WiFi card down. Be careful not to lose the metal retainer holding the antenna cables down.
    • Without applying too much force, pop out the antenna cables and remove the card.
    • Insert the new card, and reattach the antenna cables. The black cable connects to the main antenna slot (marked with a solid triangle) and the white connects to the auxiliary (marked with an empty triangle).
Matt
Membre depuis le 10/02/19
171 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 17
30 derniers jours : 47
Total : 1,748
