Introduction
The RAM is the part that collects the data for the computer. You will want to replace this because the computer is running slow. Replacing the RAM will allow the laptop to run faster.
Ce dont vous avez besoin
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
There are 2 separate RAM sticks.
Gently push down on the 2 outside tabs of the RAM stick you want to replace.
While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
5 autres ont terminé cette réparation.
