Aller au contenu principal
Dell XPS 15 9560 Touchpad Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9560 Touchpad Replacement, Back Panel: étape 1, image 1 de 1
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Touchpad Replacement: étape 2, image 1 de 1
    • Remove the ten 4.0 mm screws from the back panel of the laptop using a T5 Torx screwdriver.
  3. Dell XPS 15 9560 Touchpad Replacement: étape 3, image 1 de 1
    • Remove the two 5 mm screws underneath the XPS badge door using a Phillips screwdriver
  4. Dell XPS 15 9560 Touchpad Replacement: étape 4, image 1 de 1
    • Use a scribe to remove the bottom base cover from the backplate.
  5. Dell XPS 15 9560 Touchpad Replacement, Battery: étape 5, image 1 de 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  6. Dell XPS 15 9560 Touchpad Replacement: étape 6, image 1 de 1
    • Use your fingernails to gently "walk" the battery connector directly out of its socket.
  7. Dell XPS 15 9560 Touchpad Replacement: étape 7, image 1 de 1
    • Remove the battery.
  8. Dell XPS 15 9560 Touchpad Replacement, Hard Drive: étape 8, image 1 de 1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  9. Dell XPS 15 9560 Touchpad Replacement: étape 9, image 1 de 1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  10. Dell XPS 15 9560 Touchpad Replacement, Trackpad: étape 10, image 1 de 1
    • Remove the two 5 mm mounting screws.
  11. Dell XPS 15 9560 Touchpad Replacement: étape 11, image 1 de 1
    • Use a screwdriver to remove the single 5 mm screw securing the silver plate.
  12. Dell XPS 15 9560 Touchpad Replacement: étape 12, image 1 de 1
    • Use a spudger, pushing on alternating sides of the connector, to get it out of the socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger.
    • Don't push on the cables themselves, or you may damage the connector.
  13. Dell XPS 15 9560 Touchpad Replacement: étape 13, image 1 de 2 Dell XPS 15 9560 Touchpad Replacement: étape 13, image 2 de 2
    • Unplug the black cord.
    • Unplug the cord with a white plug.
  14. Dell XPS 15 9560 Touchpad Replacement: étape 14, image 1 de 2 Dell XPS 15 9560 Touchpad Replacement: étape 14, image 2 de 2
    • Disconnect the white ribbon cables, and use a spudger or your fingernail to gently lift the looped tab away from the connector. It should pop up easily.
    • Next, use the spudger or your fingernail to push the plastic tab away from the socket. It should move slightly.
    • Now, pull the white ribbon cables out.
  15. Dell XPS 15 9560 Touchpad Replacement: étape 15, image 1 de 1
    • Lift the laptop as shown.
    • Separate the touchpad from the keyboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 60
Total : 4,939
