Aller au contenu principal
Introduction
This guide will teach you how to replace the battery in your Dell XPS 15 9570.
This process will require a T5 Torx Screwdriver, an iFixit Opening Tool, Phillips #00 Screwdriver, and a replacement battery.
Batteries are what let your laptop hold power. A bad battery can lead to many problems. Here are some signs that your battery may need replacing:
  • The laptop will not stay on. Constant shutting down is a major sign of battery issues.
  • The laptop overheats easily. It is normal for laptops to get warm, but if yours is getting hot during small tasks, there is probably a problem with the battery.
  • The laptop will not charge properly. If the laptop takes longer than an hour to become fully charged, there is a problem.
If the battery appears to have become swollen or to have leaked, BE EXTRA CAREFUL.
Ifixit has a very helpful article on how to deal with swollen batteries:
What to Do With a Swollen iPhone Battery
(it says iPhone, but the same process goes for any lithium-ion battery)
Before starting the repair, swollen battery or not, please let the battery's charge reach 0%.
Remember that after you have successfully replaced the battery (which we are sure you will) please recycle it!
Ifixit also has an incredibly helpful article on this subject: How to Properly Recycle Your Old iPhone Battery
(again it says iPhone, but the same process goes for any lithium-ion battery)
  1. Flip the device over so the base cover of the computer is facing upwards.
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back. Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back. Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Flip open the system badge and with a Phillips #00, remove the two 8.5 mm screws. Flip open the system badge and with a Phillips #00, remove the two 8.5 mm screws.
    • Flip open the system badge and with a Phillips #00, remove the two 8.5 mm screws.
  4. Lift the back cover off of the device.
    • Lift the back cover off of the device.
  5. Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Use the iFixit opening tool to disconnect the battery connector from the motherboard.
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. With your hands, pick up and remove the battery from the system.
    • With your hands, pick up and remove the battery from the system.
2 autres ont terminé cette réparation.
Clay Caldwell
Membre depuis le 03/09/2021
232 Réputation
2 tutoriels rédigés
Équipe
University of Alabama, Team 2-4, Bedsole Fall 2021 Membre de l'équipe University of Alabama, Team 2-4, Bedsole Fall 2021
UA-BEDSOLE-F21S2G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 74
30 derniers jours : 359
Total : 1,131
