Aller au contenu principal
Dell XPS 15 9570 Touchpad Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 9570 Touchpad Replacement, Base Cover: étape 1, image 1 de 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Touchpad Replacement: étape 2, image 1 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 2, image 2 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 2, image 3 de 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Touchpad Replacement: étape 3, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement: étape 3, image 2 de 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Touchpad Replacement: étape 4, image 1 de 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Touchpad Replacement, Battery: étape 5, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Touchpad Replacement: étape 6, image 1 de 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Touchpad Replacement: étape 7, image 1 de 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Touchpad Replacement, Heat Sink: étape 8, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement, Heat Sink: étape 8, image 2 de 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Touchpad Replacement: étape 9, image 1 de 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Touchpad Replacement, Fan: étape 10, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement, Fan: étape 10, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Touchpad Replacement: étape 11, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Touchpad Replacement: étape 12, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement: étape 12, image 2 de 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Touchpad Replacement: étape 13, image 1 de 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Touchpad Replacement, RAM: étape 14, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement, RAM: étape 14, image 2 de 2
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Touchpad Replacement: étape 15, image 1 de 1
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Touchpad Replacement, SSD: étape 16, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement, SSD: étape 16, image 2 de 2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Touchpad Replacement: étape 17, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement: étape 17, image 2 de 2
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Touchpad Replacement, Wireless Card: étape 18, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement, Wireless Card: étape 18, image 2 de 2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Touchpad Replacement: étape 19, image 1 de 1
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Touchpad Replacement: étape 20, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement: étape 20, image 2 de 2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Touchpad Replacement: étape 21, image 1 de 1
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Touchpad Replacement, Speaker: étape 22, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement, Speaker: étape 22, image 2 de 2
    • Using the iFixit opening tool, disconnect the speaker cable by pulling it out gently.
  23. Dell XPS 15 9570 Touchpad Replacement: étape 23, image 1 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 23, image 2 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 23, image 3 de 3
    • Remove the four 2mm screws using the Phillips #00 screwdriver.
    • There are two on the left speaker and two on the right.
    • Follow the images for the right side to complete the left side as well.
  24. Dell XPS 15 9570 Touchpad Replacement: étape 24, image 1 de 1
    • Remove the speakers from the back of the computer.
  25. Dell XPS 15 9570 Touchpad Replacement, Touchpad: étape 25, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement, Touchpad: étape 25, image 2 de 2
    • Disconnect the two motherboard cables using the opening tool.
  26. Dell XPS 15 9570 Touchpad Replacement: étape 26, image 1 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 26, image 2 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 26, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  27. Dell XPS 15 9570 Touchpad Replacement: étape 27, image 1 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 27, image 2 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 27, image 3 de 3
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  28. Dell XPS 15 9570 Touchpad Replacement: étape 28, image 1 de 2 Dell XPS 15 9570 Touchpad Replacement: étape 28, image 2 de 2
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
  29. Dell XPS 15 9570 Touchpad Replacement: étape 29, image 1 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 29, image 2 de 3 Dell XPS 15 9570 Touchpad Replacement: étape 29, image 3 de 3
    • Using a Phillips #0 screwdriver, unscrew the two 2.4mm screws holding the touchpad in place.
    • Remove the touchpad.
Sophie
Membre depuis le 11/09/23
289 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-1, Harley Fall 2023 Membre de l'équipe IUPUI, Team 3-1, Harley Fall 2023
IUPUI-HARLEY-F23S3G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 43
Total : 359
