Aller au contenu principal
Introduction
This guide instructs you on how to replace/remove the back cover of the Dell XPS 15 9575 in order to access the internal components.
Use caution when undoing the clips that hold the cover to the case so that the laptop is secure after reassembly.
  1. For your safety, please make sure the device is powered off and the A/C adapter is unplugged. Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel. Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 327
