Aller au contenu principal
Dell XPS 15 L521X Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell XPS 15 L521X Hard Drive  Replacement, Back Panel: étape 1, image 1 de 1
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X Hard Drive  Replacement: étape 2, image 1 de 1
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X Hard Drive  Replacement, Hard Drive: étape 3, image 1 de 1
    • Find and remove the four .4cm phillips head screws holding the hard drive in place.
  4. Dell XPS 15 L521X Hard Drive  Replacement: étape 4, image 1 de 1
    • Gently unplug and remove the hard drive
2 autres ont terminé cette réparation.
SHELDON SANTOS
Membre depuis le 03/19/18
614 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G7, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G7, Covino Spring 2018
UMASSD-COVINO-S18S4G7
3 membres
6 tutoriels rédigés
Un commentaire
This was a helpful tutorial, except for two small points. #1 - The yellow & red dots on step 1 are reversed; the T5 screws are the six along the two edges of the back panel and the P0 (Phillips #0) screws are under the face plate. #2 - the battery cable should ALWAYS be unplugged for component safety prior to doing any work on a laptop. An additional safety step (though optional) would be to physically remove the battery from the laptop prior to doing any work on it.
ICU Alex - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,113
