Introduction
Replacing the ram is the easiest replacment on the Dell XPS, there are no screws to remove if you don't count the back panel. The only thing holding the RAM in place are two clips, and after unclipped the RAM slides right out.
Pièces
Aucune pièce nécessaire.
Find and remove the two .3cm torx head screws using a T5 screwdriver.
  • Find and remove the two .3cm torx head screws using a T5 screwdriver.
  • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
Ajouter un commentaire
Unplug the battery indicator.
  • Unplug the battery indicator.
  • There are two clips holding the ram in, simply unclip them
  • Gently pull the RAM out of place.
SHELDON SANTOS
Membre depuis le 19/03/2018
567 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G7, Covino Spring 2018 Membre de l'équipe UMass Dartmouth, Team S4-G7, Covino Spring 2018
UMASSD-COVINO-S18S4G7
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 40
