Aller au contenu principal
Dell XPS 15-L502X RAM Replacement
Ce dont vous avez besoin
  1. Dell XPS 15-L502X RAM Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the black battery bar from the computer before continuing any further operations.
    • Unscrew the three 5mm Phillps #2 screws on the left side of the back panel.
  2. Dell XPS 15-L502X RAM Replacement: étape 2, image 1 de 1
    • Lift up the left side of the panel.
    • There are three tabs holding in the right side of the panel. Pull the panel up and away from these tabs to remove it.
  3. Dell XPS 15-L502X RAM Replacement, RAM: étape 3, image 1 de 1
    • Locate both of the RAM slots right behind the back panel.
  4. Dell XPS 15-L502X RAM Replacement: étape 4, image 1 de 1
    • Use a black spudger to press the clips holding the RAM outward. You should hear a "click" sound.
    • Once both clips have been released, the RAM will be released at a 45 degree angle.
  5. Dell XPS 15-L502X RAM Replacement: étape 5, image 1 de 1
    • Carefully grab the RAM with both hands and pull outward.
    • Repeat steps 4 & 5 to remove the second RAM.
    • Both RAMs should come out without much force. Do not attempt to pull the RAM out with force as this could damage the fixture holding the RAM.
Vishal
Membre depuis le 09/21/15
772 Réputation
6 tutoriels rédigés
Équipe
IUPUI, Team 2-3, Baechle Fall 2015 Membre de l'équipe IUPUI, Team 2-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 2,100
