Aller au contenu principal
Dell XPS 17 L702X Palm Rest Replacement
Ce dont vous avez besoin
  1. Dell XPS 17 L702X Palm Rest Replacement, Battery: étape 1, image 1 de 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Palm Rest Replacement: étape 2, image 1 de 2 Dell XPS 17 L702X Palm Rest Replacement: étape 2, image 2 de 2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Palm Rest Replacement: étape 3, image 1 de 2 Dell XPS 17 L702X Palm Rest Replacement: étape 3, image 2 de 2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Palm Rest Replacement, Hard Drive: étape 4, image 1 de 1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Palm Rest Replacement: étape 5, image 1 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 5, image 2 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 5, image 3 de 3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Palm Rest Replacement: étape 6, image 1 de 2 Dell XPS 17 L702X Palm Rest Replacement: étape 6, image 2 de 2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Palm Rest Replacement: étape 7, image 1 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 7, image 2 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 7, image 3 de 3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Palm Rest Replacement: étape 8, image 1 de 1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Palm Rest Replacement: étape 9, image 1 de 2 Dell XPS 17 L702X Palm Rest Replacement: étape 9, image 2 de 2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Palm Rest Replacement: étape 10, image 1 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 10, image 2 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 10, image 3 de 3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Palm Rest Replacement: étape 11, image 1 de 2 Dell XPS 17 L702X Palm Rest Replacement: étape 11, image 2 de 2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Palm Rest Replacement: étape 12, image 1 de 1
    • Remove the hard drive casing.
  13. Dell XPS 17 L702X Palm Rest Replacement, Palm Rest: étape 13, image 1 de 1
    • Unscrew the screw holding the optical drive with a Phillips screwdriver.
  14. Dell XPS 17 L702X Palm Rest Replacement: étape 14, image 1 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 14, image 2 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 14, image 3 de 3
    • Using a plastic opening tool, pull out the optical drive.
  15. Dell XPS 17 L702X Palm Rest Replacement: étape 15, image 1 de 1
    • Unscrew three 4mm screws near the edge of the optical drive compartment with a Phillips screwdriver.
  16. Dell XPS 17 L702X Palm Rest Replacement: étape 16, image 1 de 1
    • Open the laptop to about a 90 degree angle and place it on its side with the empty optical drive slot pointing upwards.
  17. Dell XPS 17 L702X Palm Rest Replacement: étape 17, image 1 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 17, image 2 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 17, image 3 de 3
    • Push and hold the tab inside the optical drive's opening with your index finger.
    • Insert a spudger between the black and silver plastic pieces that are above the tab and pry apart the two pieces.
  18. Dell XPS 17 L702X Palm Rest Replacement: étape 18, image 1 de 2 Dell XPS 17 L702X Palm Rest Replacement: étape 18, image 2 de 2
    • Slide the spudger around the palm rest to release the clips.
    • You may hear a crackling noise; this is normal.
    • Use caution when sliding below the mouse pad, as there are wires we must detach in the next steps.
  19. Dell XPS 17 L702X Palm Rest Replacement: étape 19, image 1 de 2 Dell XPS 17 L702X Palm Rest Replacement: étape 19, image 2 de 2
    • Gently lift and rotate the palm rest panel until it's upside down as it is still connected by the mouse pad wires.
    • The mouse pad wires are still connected to the palm rest panel.
  20. Dell XPS 17 L702X Palm Rest Replacement: étape 20, image 1 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 20, image 2 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 20, image 3 de 3
    • Put the spudger below the black tab of the wider cable and push up to release.
    • Gently pull out the cable.
  21. Dell XPS 17 L702X Palm Rest Replacement: étape 21, image 1 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 21, image 2 de 3 Dell XPS 17 L702X Palm Rest Replacement: étape 21, image 3 de 3
    • Insert the spudger below the black tab of the remaining cable and push up to release.
  22. Dell XPS 17 L702X Palm Rest Replacement: étape 22, image 1 de 1
    • Remove the palm rest from the laptop.
Shin Sul
Membre depuis le 10/02/15
544 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 2-6, Bruce Fall 2015 Membre de l'équipe CSU Fullerton, Team 2-6, Bruce Fall 2015
CSUF-BRUCE-F15S2G6
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 13
Total : 1,200
