Aller au contenu principal
Dell XPS 720 H2C Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: étape 1, image 1 de 2 Dell XPS 720 H2C Hard Drive Replacement, Removing Dell XPS 720 H2C Cover Panel: étape 1, image 2 de 2
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  2. Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: étape 2, image 1 de 2 Dell XPS 720 H2C Hard Drive Replacement, Hard Drive: étape 2, image 2 de 2
    • The hard drive is located the top-center area of the computer.
    • Carefully disconnect the data and power cables from the hard drive.
  3. Dell XPS 720 H2C Hard Drive Replacement: étape 3, image 1 de 1
    • Push the tabs on both sides of the hard drive bracket towards each other and slide the hard drive up and out of the hard drive bay.
  4. Dell XPS 720 H2C Hard Drive Replacement: étape 4, image 1 de 2 Dell XPS 720 H2C Hard Drive Replacement: étape 4, image 2 de 2
    • Unscrew the four 5mm screws on both sides of the hard drive using the Phillips #1 screwdriver and then remove the hard drive from the case.
2 autres ont terminé cette réparation.
G B
Membre depuis le 04/17/13
67 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,697
