Aller au contenu principal
Dell XPS 7590 RAM Replacement
Ce dont vous avez besoin
  1. Dell XPS 7590 RAM Replacement, Flip laptop around: étape 1, image 1 de 1
    • Flip your device the other way around
    • Don't be confused that this device is black, its a skin
  2. Dell XPS 7590 RAM Replacement, Remove 10 Torx T5: étape 2, image 1 de 3 Dell XPS 7590 RAM Replacement, Remove 10 Torx T5: étape 2, image 2 de 3 Dell XPS 7590 RAM Replacement, Remove 10 Torx T5: étape 2, image 3 de 3
    • Grab your T5 Torx and identify the 10 torx screws
    • Make sure that this is a T5, to not strip the screws. They can be very difficult to remove
    • Careful there are more screws, do not try to open yet!
  3. Dell XPS 7590 RAM Replacement, Remove Flap Screws: étape 3, image 1 de 1
    • Open the flap on the back of the laptop
    • There are two screws that need to be removed, please use a Philips 0 screwdriver
  4. Dell XPS 7590 RAM Replacement, Remove Backplate: étape 4, image 1 de 1
    • The backplate might not be easy to open
    • You can use a soft prytool to open the laptop easier
    • Don't insert the tool too deep or you might break the mainboard
    • Now, you should be able to remove the backplate
  5. Dell XPS 7590 RAM Replacement, Unplug Battery: étape 5, image 1 de 3 Dell XPS 7590 RAM Replacement, Unplug Battery: étape 5, image 2 de 3 Dell XPS 7590 RAM Replacement, Unplug Battery: étape 5, image 3 de 3
    • Locate the battery connection to the mainboard
    • Unplug the battery before doing anything else
    • You can use a pry tool to make this easier
  6. Dell XPS 7590 RAM Replacement, Locate and remove RAM: étape 6, image 1 de 2 Dell XPS 7590 RAM Replacement, Locate and remove RAM: étape 6, image 2 de 2
    • Locate the RAM on the mainboard
    • Gently push down on the 2 outside tabs of the RAM stick you want to replace
    • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up
    • Firmly grasp the RAM stick from the flipped up edge and gently pull out, releasing the RAM stick
  7. Dell XPS 7590 RAM Replacement, Insert new RAM: étape 7, image 1 de 3 Dell XPS 7590 RAM Replacement, Insert new RAM: étape 7, image 2 de 3 Dell XPS 7590 RAM Replacement, Insert new RAM: étape 7, image 3 de 3
    • Insert the new RAM sticks into the socket or reseat the one that is already there if the ram is not detecting properly
    • Make sure to align the RAM properly in the slot before pressing down
    • Then press down to have the RAM to seat in correctly
  8. Dell XPS 7590 RAM Replacement, Plug battery back in and reassemble: étape 8, image 1 de 1
    • Plug battery back in
    • Place backplate on top again and reassemble
3 autres ont terminé cette réparation.
Max Lembke
Membre depuis le 09/14/19
924 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 59
Total : 3,204
