Introduction
If your fan needs to be replaced, remove the back panel using this guide. For this guide, you will need a Phillips screwdriver with a PH01 head and tweezers. This process will be relatively easy to follow along, with only a couple steps needing careful focus to prevent damage to the laptop itself.
Ce dont vous avez besoin
Remove the four 5.0mm screws with a Phillips #1 screwdriver.
Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
Remove the fan cover.
Remove the wire bay near the fan.
Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
Gently pull upward while moving your hand side to side so the plastic holder will detach.
