Aller au contenu principal
Dell XPS M1530 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell XPS M1530 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn the computer upside down with the battery facing you.
    • Turn the computer off and disconnect the charging cable from the computer.
    • Failure to unplug the charging cable may result in electric shock.
  2. Dell XPS M1530 Hard Drive Replacement: étape 2, image 1 de 1
    • Push the switch as far to the right as possible to unlock the battery.
  3. Dell XPS M1530 Hard Drive Replacement: étape 3, image 1 de 2 Dell XPS M1530 Hard Drive Replacement: étape 3, image 2 de 2
    • Remove the battery using two hands and pull it away from the computer.
  4. Dell XPS M1530 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 Dell XPS M1530 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Remove the four Phillips #1 screws holding the Hard Drive in place.
    • Four 3.5mm Phillips #1 screws
  5. Dell XPS M1530 Hard Drive Replacement: étape 5, image 1 de 2 Dell XPS M1530 Hard Drive Replacement: étape 5, image 2 de 2
    • Pull the Hard Drive out gently using the tab. It should provide enough leverage to pull the drive out smoothly.
  6. Dell XPS M1530 Hard Drive Replacement: étape 6, image 1 de 2 Dell XPS M1530 Hard Drive Replacement: étape 6, image 2 de 2
    • Remove both 3.5mm Phillips #1 screws on either side of the plastic casing.
    • There is a second screw on the other side of the casing.
    • Then gently separate the drive from its casing.
Tyler Scholz
Membre depuis le 01/22/15
479 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 18-4, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 18-4, Maness Winter 2015
CPSU-MANESS-W15S18G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 2,044
