Introduction
If your computer is still running hot after cleaning the fan, you should remove the heat sink to check that it is not damaged.
Ce dont vous avez besoin
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
