Aller au contenu principal
Dell XPS M170 MXG051 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell XPS M170 MXG051 Memory Module Replacement, Dell XPS M170 MXG051 Battery Removal: étape 1, image 1 de 1
    • Turn off your computer. Then, disconnect your computer and all attached devices from their electrical outlets.
    • Close the display and turn the computer upside down on a flat work surface.
    • Slide the battery-bay latch release on the bottom of the computer and remove the battery from the bay.
  2. Dell XPS M170 MXG051 Memory Module Replacement, Remove Memory Module Cover: étape 2, image 1 de 1
    • Loosen the two captive screws from the memory module cover, and remove the cover.
  3. Dell XPS M170 MXG051 Memory Module Replacement: étape 3, image 1 de 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module(s) from the connector at a 45 - degree angle.
  4. Dell XPS M170 MXG051 Memory Module Replacement, Install New Memory: étape 4, image 1 de 1
    • Align the notch in the new memory module's edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot at a 45 - degree angle, and press the the module down (so that it is horizontal. If you do not feel the memory module click into place after you press it down, remove the module and reinstall it.
  5. Dell XPS M170 MXG051 Memory Module Replacement: étape 5, image 1 de 1
    • Replace the memory cover and tighten the captive screws.
Ligne d'arrivée
Johnathan Hammond
Membre depuis le 02/28/18
44 820 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 93
