Pièces
Aucune pièce nécessaire.
Push the sliding button near the battery compartment.
  • Push the sliding button near the battery compartment.
Ajouter un commentaire
Slide the button next to the battery and lift up on the lip of the battery edge.
  • Slide the button next to the battery and lift up on the lip of the battery edge.
  • Lift and remove the battery.
  • Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
  • Remove the four screws from the top of the keyboard bracket.
  • Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
  • Lift the keyboard about 2 inches up from the laptop platform.
  • From this angle the keyboard ribbon connector can be seen and disconnected.
  • Remove 2 M2x3mm screws that are located at the bottom of the plastic bezel with a PH0 screwdriver.
  • Use iFixit plastic tool and a cutout of cardboard to pry out the plastic bezel around the edges of the LCD screen
  • Disconnect the display connectors by removing them from the grooves and unplugging them.
  • Remove 12 M2x3mm screws along the edge of the screen frame with a PH0 screwdriver.
  • Disconnect the display connector behind the top of the screen.
  • Remove the four screws (M2x3mm) surrounding the webcam
  • Lift up on the webcam bar to pull it out.
  • Remove webcam bar and the metal tray underneath.
  • Your webcam is now removed.
Natalie King
Membre depuis le 08/02/2018
147 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 42
